[postgis-users] Help, I seem to be missing a very basic concept
Stephen Woodbridge woodbri at swoodbridge.com
Sun Dec 18 08:05:56 PST 2005
Hi all,
I feel very dumb to have to ask this question, but I seem to be missing
a very basic concept or I need more coffee to jump start my brain ...
The postGIS documentation uses a term "geometry set", which doesn't seem
to be defined, what is this and how do I create it. I assumed it meant
the rows resulting from a select.
But I can not get something as basic as the following to work:
select geomunion((select the_geom from county where ssccc/1000=25));
ERROR:  more than one row returned by a subquery used as an expression
select geomunion(collect((select the_geom from county where
ssccc/1000=25)));
ERROR:  aggregate function calls may not be nested
So, how do I do something like this?
I'm using:
"PostgreSQL 8.0.4 on i386-portbld-freebsd5.3, compiled by GCC cc (GCC)
3.4.2 [FreeBSD] 20040728"
"POSTGIS="1.0.5" GEOS="2.2.0" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0""
Thanks,
   -Steve W.
