[postgis-users] Help, I seem to be missing a very basic concept
Stephen Woodbridge woodbri at swoodbridge.com
Sun Dec 18 08:26:46 PST 2005
Never mind. I figured it out.
select geomunion(the_geom) from county where ssccc/1000=25;
need more coffee :)
-Steve
Stephen Woodbridge wrote:
> Hi all,
> I feel very dumb to have to ask this question, but I seem to be missing
> a very basic concept or I need more coffee to jump start my brain ...
> The postGIS documentation uses a term "geometry set", which doesn't seem
> to be defined, what is this and how do I create it. I assumed it meant
> the rows resulting from a select.
> But I can not get something as basic as the following to work:
> select geomunion((select the_geom from county where ssccc/1000=25));
> ERROR:  more than one row returned by a subquery used as an expression
> select geomunion(collect((select the_geom from county where
> ssccc/1000=25)));
> ERROR:  aggregate function calls may not be nested
> So, how do I do something like this?
> I'm using:
> "PostgreSQL 8.0.4 on i386-portbld-freebsd5.3, compiled by GCC cc (GCC)
> 3.4.2 [FreeBSD] 20040728"
> "POSTGIS="1.0.5" GEOS="2.2.0" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.0" RELPROC="0.3.0""
> Thanks,
>   -Steve W.
> postgis-users mailing list
