[postgis-users] transform() does not do work for NGO1948 zone III -> WGS84 longlat (epsg:27393->epsg:4326)
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Dec 20 08:46:16 PST 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Havard Tveite
> Sent: 20 December 2005 15:12
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] transform() does not do work for NGO1948 zone III
(cut)
> When using transform() in postgis, however, the longitude of origin
> (+lon_0=-10.72291666666667) seems to be ignored, and there seems to
> be no datum shift performed
> (+towgs84=278.3,93,474.5,7.889,0.05,-6.61,6.21).
> Longitude of origin (+lat_0=58) seems to be used correctly.
Hi Havard,
Actually, looking through the source lwgeom_transform.c I see the following
comment around line 500:
//this is *exactly* the same as PROJ.4's pj_transform(), but it doesn't
//do the datum shift.
So does this mean that the PostGIS transform() function won't do datum
shifts? Can anyone with a bit more PROJ4 knowledge say if this is correct,
and if so, why PostGIS can't support it?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
