[postgis-users] transform() does not do work for NGO1948 zone III-> WGS84 longlat (epsg:27393->epsg:4326)
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Dec 21 02:10:01 PST 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of strk at refractions.net
> Sent: 21 December 2005 08:19
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] transform() does not do work for NGO1948 zone
> On Tue, Dec 20, 2005 at 04:56:47PM -0500, Frank Warmerdam wrote:
> > Error -38 is:
> >  	"failed to load NAD27-83 correction file",  	/* -38 */
> > So basically, if the datum shift files are not found, then the
> > code fallback to trying a conversion without the datum shift.
> Thank you Frank,
> maybe we should raise a WARNING in that case ? I mean, is
> "shift files not found" condition a sign of incomplete
> installation of PROJ4 ?
I would say a warning should definitely be given if the transformation being
done is not the one that was requested by the user.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
