[postgis-users] N-Point Buffer
Stefano B. stefano.bonnin at comai.to
Wed Dec 21 02:58:09 PST 2005
thanks
but the function azimuth is only on cvs 1.1 version?
and where is the online documentation?
It seems that the documentation link is wrong (on postgis site). If I try to
get the online documentation the link give me the pdf documentation file (I
think this file is older that the online docs).
I ask this questions because I don't know how to use the azimuth function. I
see on the web something like
azimuth(Geometry,Geometry)
You said me:
> 2) Order points by azimuth from [C] (Azimuth)
but I don't undestand how to use the azimuth function in order to to this.
(perhaps have I to insert the points in the first parameter and the centroid
in the second one?)
Very thanks for your help!
Stefano
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Wednesday, December 21, 2005 9:47 AM
Subject: Re: [postgis-users] N-Point Buffer
> On Wed, Dec 21, 2005 at 09:37:59AM +0100, Stefano B. wrote:
> > Hi,
> > I have different set of points on my map. I'd like to create a buffer
(poligon) for each set (in order to display different "background areas" for
each set).
> > So, how can I create a "buffer area" for a set of points?
> > The first idea:
> >     - find the poligon that contains this points (1)
> >     - create a buffer of this poligon (2)
> > (1) it seems, to me,  difficult (or not?)
> > (2) ...
> > if is it the right way to do this, how can I find the polygon?
> > if it is the wrong way, what is the best method to to this?
> This is just an idea:
> 1) Build a multipoint and find it's centroid [C] (Collect, Centroid)
> 3) Build a line using ordered points (MakeLine)
> 4) Close the line (AddPoint, PointN)
> 5) Build a polygon (MakePolygon)
> 6) Buffer
> Sounds like possible with a single query ...
> --strk;
> postgis-users mailing list
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.371 / Virus Database: 267.14.2/208 - Release Date: 20/12/2005
