[postgis-users] Problem compiling PostGIS 1.10
Uwe Seher useher at web.de
Wed Dec 28 06:47:14 PST 2005
Hello Group!
I have a problem in compiling postgis 1.10. I untared it in the sourcetree
of postgres 8.1.1, installed plpgsql, create a database 'postgis_reg', a
role 'root', all what it wantend ;)
Then i tried to to compile, which ends up in this errormessages:
lwgeom_transform.c: In function `pj_transform_nodatum':
lwgeom_transform.c:514: error: structure has no member named `is_latlong'
lwgeom_transform.c:533: error: structure has no member named `is_latlong'
lwgeom_transform.c: In function `transform_point':
lwgeom_transform.c:926: error: structure has no member named `is_latlong'
lwgeom_transform.c:927: warning: implicit declaration of function
`pj_transform'
lwgeom_transform.c:947: error: structure has no member named `is_latlong'
make[1]: *** [lwgeom_transform.o] Error 1
make[1]: Leaving directory
`/root/archive/postgresql-8.1.1/contrib/postgis-1.1.0/lwgeom'
make: *** [liblwgeom] Error 2
So, what is going wrong?
Thank you for your help
Uwe Seher
System is SuSE 9.2, with Geos 2.1.2, Proj 4.4.1
____________
Virus checked by G DATA AntiVirusKit
Version: AVK 16.2472 from 28.12.2005
Virus news: www.antiviruslab.com
