[postgis-users] problem with shp2pgsql
Stephen Woodbridge woodbri at swoodbridge.com
Wed Dec 28 12:33:04 PST 2005
henok tadesse wrote:
> thanks  every body,
> i actually have already loaded all the shape files  in the folder where
> the shp2pgsql exists.
> so i considered the hint to include the myschema thing...
>     ./shp2pgsql -s 26911  River.shp River myschema.myRiverdb > River.sql
> but still it returns >> bash: River.sql: Permission denied
> it looks like there is a brain cracking challenge at every step of this
> code...well atleast
> it doesnot say this time that  the shape files cannot be opened!  Any
> idea why I am not
> allowed to create the river.sql --- i am thankful for the explanation as
> always!
You do not have permission to create files in the current working
directory whatever that is. Try instead:
./shp2pgsql -s 26911  River.shp River myschema.myRiverdb > ~/River.sql
then look in your home directory for ~/River.sql
-Steve W.
> henok
> */Barend Köbben <kobben at itc.nl>/* wrote:
>     Hi Henok,
>     possible solutions:
>     1) you do not include the [schema.]database in the paramters. Not
>     sure if it is required, but it might be, so uit would be:
>     ./shp2pgsql -s 26911 River.shp River [mySchema.]myDB> River.sql
>     2) you have only copied the *.shp file to the loader directory, but
>     not the other associated (and needed fiel). These include at least
>     *.dbf and *.shx , in many cases also *.sbn, *.prj or *.sbx
>     keep trying ;-)
>     ____________________________
>     Barend Köbben
>     International Institute for Geo-information Sciences and Earth
>     Observation (ITC)
>     PO Box 6, 7500AA Enschede (The Netherlands)
>     ph: +31-(0)534874253; fax: +31-(0)534874335
>     _____________________________
>     ________________________________
>     From: postgis-users-bounces at postgis.refractions.net on behalf of
>     henok tadesse
>     Sent: Wed 28.12.2005 14:37
>     To: PostGIS Users Discussion
>     Subject: RE: [postgis-users] problem with shp2pgsql
>     Thanks for the hint... but i now have corrected the path problems
>     but i continue to have problems. i am actually working in linux and
>     the shapefile is in the same folder as the shp2pgsql.
>     ./shp2pgsql -s 26911 River.shp River > River.sql
>     or i have also tried this one...
>     /shp2pgsql -s 26911 River.shp River | psql myRiverdb.sql
>     I am using the shapefile and tutorial from carto.net just to first
>     test if it works but in
>     both cases, it returns River.shp: shape (.shp) or index files (.shx)
>     can not be opened.
>     I really do understand this. why it cannot be opened?
>     with thanks in advance,
>     Barend Köbben wrote:
>     What they mean is: If the shapefile is in the "loader directory" (ie
>     the directory the shp2pgsql executable is in) you only need to
>     specify the shapefiles name, otherwise make sure you state the full
>     path:
>     eg. for windows:
>     shp2pgsql.exe C:\mydirectory\asubdirectory\myshapefile.shp mytable myDB
>     Barend Köbben
>     Observation (ITC)
>     henok tadesse
>     Sent: Tue 27.12.2005 20:15
>     To: postgis-users at postgis.refractions.net
>     Subject: [postgis-users] problem with shp2pgsql
>     hello,
>     I was trying to load a shape file into my postgis database. Some
>     body in this forum once said the shapefile should be put in the
>     loader directory. But i could not really find out where the loader
>     directory is although i used this command to load the dumper!
>     # cd postgis-1.1.0/loader
>     # make
>     # make install
>     Should the shape file necessarily be in the loader dirctory to be
>     used in shp2pgsql? if yes, where can i find it?
>     thanks in advance,
>     henok
>     Yahoo! Photos - NEW, now offering a quality print service from just
>     8p a photo.
>     _______________________________________________
>     postgis-users mailing list
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
>     To help you stay safe and secure online, we've developed the all new
>     Yahoo! Security Centre .
> *Yahoo! Photos*
> <http://us.rd.yahoo.com/mail/uk/taglines/default/photos/*http://uk.photos.yahoo.com/>
> – NEW, now offering a quality print service
> from just 8p a photo.
