[postgis-users] About Invalid OGC WKT Error
strk at refractions.net strk at refractions.net
Wed Feb 2 10:29:15 PST 2005
On Wed, Feb 02, 2005 at 01:18:15PM -0500, Kralidis,Tom [Burlington] wrote:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Markus Schaber
> > Sent: Wednesday, 02 February, 2005 12:51
> > To: PostGIS Users Discussion
> > Subject: Re: [postgis-users] About Invalid OGC WKT Error
> > Hi, Tom,
> > Kralidis,Tom [Burlington] schrieb:
> > > How does affect the MapServer connections to PostGIS?
> > To be honest, I don't know. That depends on which method
> > MapServer uses to access PostGIS. As I never used MapServer,
> > I have no idea.
> > When using the JDBC classes, replacing the postgis.jar in the
> > classpath should be enough. Equally, any other toolkit should
> > provide its update, with noch changes to mapserver itsself.
> > When using OpenGIS methods (asText() or asBinary() etc.), no
> > changes should be necessary.
> > When using PostGIS specific, like "SELECT geom FROM table;"
> > then MapServer will need a new HexWKB parser or be changed to
> > use OpenGIS methods or the new asEWKT() PostGIS specific methods.
> MapServer connects via (user config):
> DATA "the_geom from table_name"
> Does one need to pass a function (like asEWKT(the_geom from table) on this?  I'm not sure how this is evaluated in the MapServer / PostGIS connector code itself, though.
I think it should be transparent. Did you have problems ?
--strk;
> ..Tom
> > Markus
> > markus schaber | dipl. informatiker
> > logi-track ag | rennweg 14-16 | ch 8001 zürich
> > phone +41-43-888 62 52 | fax +41-43-888 62 53
> > mailto:schabios at logi-track.com | www.logi-track.com
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
