[postgis-users] transform function
Jean-Denis Giguere jdenisgiguere at fastmail.fm
Fri Feb 11 09:47:56 PST 2005
Greetings,
I would like to reproject data  obtained with ogr2ogr. Sadly, I get all
result with an empty geometry description.
ogr2ogr generate spatial_ref_sys entry with the following fields : oid,
srid and srtext (not proj4text).
If I change the srid to a value generated by spatial_ref_sys.sql,
everything works well. Do we need the proj4text column in
spatial_ref_sys to use transform function ?
Jean-Denis
Jean-Denis Giguère
Étudiant en géomatique
appliquée à l'environnement
Stagiaire à l'Agence de développement
de réseaux locaux de services de santé
et de services sociaux de l'Estrie
Tél. 829-3400 42008
Courriel. jdenisgiguere at fastmail.fm
