[postgis-users] Does PostGIS 1.0RC1/2 work with MS4W/Mapserver 4.4.1?
Dirk Jesko jesko at geocontent.de
Mon Feb 14 09:45:12 PST 2005
>>I am pretty sure that is the same issue. Until now I tested several
>>installation with always the same result: No mapserver will display
>>points coming from a PostGIS 1.0.0RC1 or newer.
>>I would really be interested whether this is caused by Mapserver or
>>PostGIS. Since the 0.9.x work and there are also no problems with other
>>geometry types like polygon or line, I doubt that the problem is caused
>>by the mapserver.
>You might want to try postgis from current CVS, or wait for RC3, as
>memory alignment problems might have a role in this situation.
>Please let me know if you try.
Unfortunately, I currently do not have time to test a different version.
Maybe in one or two weeks. I will let you know then.
>Also, do you confirm POINT are the
>only geometry you have problems with ? I've had reports of problems
>with POLYGONS as well (but not with MULTIPOLYGONS).
I just checked and realized that all my geometries are MULTIPOLYGONS, so
I am not sure about POLYGONS.
