[postgis-users] View area
strk at refractions.net strk at refractions.net
Tue Feb 15 11:26:15 PST 2005
On Tue, Feb 15, 2005 at 11:28:28AM -0700, Sean M. Montague wrote:
> For some reason this returns as SVG a bunch of points.  My whole
> statement is below.
Use summary() instead of assvg to have a readable description
of what is returned by that query.
--strk;
> SELECT AsSVG(intersection(the_geom, setSRID('BOX3D(xxx yyy, xxx
> yyy)'::box3d,42102)),0,8)
> As the_geom From usa
> WHERE the_geom && setSRID('BOX3D(xxx yyy, xxx yyy)'::box3d,42102);
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Tuesday, February 15, 2005 10:52 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] View area
> Intersection should do.
> Don't use GeomFromText() with anything but OGC Well Known Text format.
> Try something like this:
> setSRID('BOX3D(...)'::box3d,42102)))
>  WHERE the_geom && setSRID('BOX3D(...)'::box3d,42102);
> --strk;
> On Tue, Feb 15, 2005 at 10:47:32AM -0700, Sean M. Montague wrote:
> > I sent this in response to the wrong post.
> > The select statement below is close to what I'm looking for.  I don't
> > know if I'm imagining this, but I thought it was possible to define a
> > box and extract just what is inside that box, clipping all that lies
> > outside, including polygons.  Is this possible using a different sql
> > statement?
> > SELECT AsSVG(the_geom,0,8) as the_geom FROM usa WHERE the_geom &&
> > GeomFromText('BOX3D(-2243528 2679134,-1689106 2002338)'::box3d,42102);
> Sean
> > M. Montague
> > Sent: Monday, February 14, 2005 5:42 PM
> > Subject: [postgis-users] View area
> > Is there a way to extract data based on viewable area coordinates.
> For
> > instance, can I extract roads that are only within my viewer area, or
> > part of a polygon, but not the whole thing?  I've tinkered with
> > intersection, but have failed to accomplish anything.  Thanks.
> > Sean
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
