[postgis-users] Using exteriorring
strk at refractions.net strk at refractions.net
Fri Feb 18 08:27:49 PST 2005
On Fri, Feb 18, 2005 at 05:04:19PM +0100, Benoit Ogier wrote:
> Hi,
> I would use the exteriorring function to get the exterior ring of multi
> polygons, convert them to a single poly and store result in a new field
> of my table "poly_test".
> using this sql command :
> update nt_ownership_ew SET the_geom2 = exteriorring(the_geom)
> I get :
> ERROR:  new row for relation "poly_test" violates check constraint "enforce_geotype_the_geom2"
> the_geom is MULTIPOLYGON kind,
> the_geom2 is POLYGON kind,
> Questions :
> - Is it the recommanded way to convert multi-polys to single polys ?
> - If yes, where is the error ?
You did everything the way you should, just a question, which
geometry type did you specify in the AddGeometryColumn() call
to create the poly_test field ?
--strk;
> Thanks,
> BO
> Benoît Ogier{
> Carte Blanche Conseil
> 47, rue de Lancry
> 75010 Paris
> Tel : +33 1 42 41 21 21
> Fax : +33 1 42 41 70 40
> email : benoit.ogier at cbconseil.com
> postgis-users mailing list
