[postgis-users] Installing postgis-0.9.1
Shaq Gbadebo s_gbadebo at hotmail.com
Wed Feb 23 05:56:48 PST 2005
I can not find that folder, in the postgresql directory. The only libpostgis
file is in the postgis directory which is in the postgresql contrib folder.
>From: strk at refractions.net
>Reply-To: PostGIS Users Discussion
<postgis-users at postgis.refractions.net>
>To: postgis-users at postgis.refractions.net
>Subject: Re: [postgis-users] Installing postgis-0.9.1
>Date: Wed, 23 Feb 2005 14:03:33 +0100
>On Wed, Feb 23, 2005 at 12:47:47PM +0000, Shaq Gbadebo wrote:
> > Thank you for your reply.
> > 1. I did run make install from the postgis directory.
> > 2. The libpostgis library is in the postgis directory.
>make install should have installed it in the PostgreSQL
>directory, not the PostGIS directory. Check to see if
>it's there (should be in the directory printed by pg_config
--pkglibdir).
>--strk;
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
