AW: [postgis-users] Postgis updates w/ JUMP driver.
Jason Leach jason.leach at gmail.com
Thu Feb 24 00:02:13 PST 2005
Can you tell me what file/line you had to hack?  I'll change mine
since we mostly work in the same SRID.
Thanks for the reply,
Jason.
On Thu, 24 Feb 2005 07:41:52 +0100, "Weßling, Achim"
<Achim.Wessling at gt-net.de> wrote:
> Hi,
> I had the same problem. It looks like the driver uses allways -1 as SRID. I
> fixed it, by hacking the source. I hardcoded the SRID I allways use. Not
> perfect, but works for me ;-).
> Greatings,
> Achim
> -----Ursprüngliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Im Auftrag von
> Jason Leach
> Gesendet am: Mittwoch, 23. Februar 2005 18:35
> An: postgis-users at postgis.refractions.net
> Betreff: [postgis-users] Postgis updates w/ JUMP driver.
> hi,
> I posted this question here since this questions is about the jump
> driver, made by the same people who make postgis.
> When updating a dataset via Jump I  get the error, "violates check
> constraint 'enforce_srid_the_geom'.  If I write some beanshell code to
> iterate through the features all the SRIDs are all set to 0.  So my
> guess is the drivers code is not setting the SRID when it queries the
> database (PostGIS).
> Does anyone have comments on this?  I have the SRID set properly in
> the DB, but perhaps I am missing something?  Works fine if I to a
> query and to srid(the_geom).
> Using Jump (1.1.2 and 1.1.1) and postgisdriver (1.1.0 or 1.2.0).
> Thanks,
> Jason.
> postgis-users mailing list
