[postgis-users] Re: Problems compililng postgis-1.0.0RC2 and RC3 with proj4 support]
Donald J Miller Donald.J.Miller at noaa.gov
Thu Feb 24 13:04:09 PST 2005
Hello again!
I found the source of the problem.  Apparently I indadvertenly installed
an older version of Proj 4 rpm (4.4.4.1) by mistake.  I compiled the
latest version of Proj4 and now postgis 1.0RC3 compiles fine.
Don
Donald J. Miller III wrote:
> Hello,
> I am attempting to compile postgis 1.0 RC2 and RC3 with GEOS and Proj
> 4 support but to no avail.  I even get failures with 0.9.1.  I am
> running postgres 8.0.1, compiled with -lstdc++, geos 2.1.1 and proj
> 4.4.9.
> Make returns the following errors:
> make -C lwgeom
> make[1]: Entering directory
> `/tmp/postgresql-8.0.1/contrib/postgis/lwgeom'
> sh ../geos_version.sh /usr/local > postgis_geos_version.h
> gcc -I/usr/local/ssl/include -Wall -Wmissing-prototypes
> -Wpointer-arith -Wdeclaration-after-statement -fno-strict-aliasing -g
> -fexceptions -fPIC -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.0.0RC3"'
> -DPOSTGIS_SCRIPTS_VERSION='"0.2.0"' -DPOSTGIS_BUILD_DATE='"2005-02-24
> 19:52:20"' -I/usr/local/include -DUSE_GEOS -I/usr/local/include
> -DUSE_PROJ  -I/usr/local/include -DAUTOCACHE_BBOX=1  -DUSE_STATS -fpic
> -I/tmp/postgresql-8.0.1/contrib/postgis/../../src/include
> -D_GNU_SOURCE   -c -o lwgeom_transform.o lwgeom_transform.c
> make[1]: Leaving directory `/tmp/postgresql-8.0.1/contrib/postgis/lwgeom'
> lwgeom_transform.c: In function `pj_transform_nodatum':
> lwgeom_transform.c:59: structure has no member named `is_latlong'
> lwgeom_transform.c:78: structure has no member named `is_latlong'
> lwgeom_transform.c: In function `transform_point':
> lwgeom_transform.c:352: structure has no member named `is_latlong'
> lwgeom_transform.c:353: warning: implicit declaration of function
> `pj_transform'
> lwgeom_transform.c:371: structure has no member named `is_latlong'
> make[1]: *** [lwgeom_transform.o] Error 1
> make: *** [liblwgeom] Error 2
> Thanks for any assistance.
> Don
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050224/48754db2/attachment.vcf>
