[postgis-users] distance_spheroid and index files
Jonas Wolf wolfey at gmx.net
Sun Feb 27 04:14:27 PST 2005
Just to clarify, distance_spheroid is available, distance_sphere is not.
Stupid me.
> Thanks for all the replies.
> I actually don't mind getting "kind of right" answers, so
> distance_sphere seems like the right choice. However, for some reason
> this function does not seem to exist. I installed PostgreSQL 7.3.4,
> Proj4 4.4.9 and GEOS 2.1.1 on Mandrake Linux. I then downloaded Postgis
> RC 3, updated the Makefile.config USE_PROJ and USE_GEOS variables, ran
> make and make install, with no errors. I set up the database and ran
> lwpostgis.sql on it. Now distance_sphere is available, as I said I've
> been using it. But no distance_sphere. Does that make any sense?
> Shouldn't this function be defined in lwpostgis.sql, like
> distance_sphere? Because it's not in there. I'm quite confused, does
> anybody have a clue what I might have done wrong?
> Thanks, Jonas
