[postgis-users] Possible issue with Geos on PostgreSQL 8.0 Native Windows
Paul Ramsey pramsey at refractions.net
Wed Jan 12 07:51:28 PST 2005
Doh. This sounds like the original problem we had with GEOS, which is
that the C++ exceptions are interpretted as signals by the PostgreSQL,
in particular a signal to die, die, die. The problem appeared to be
quietly "going away", I think as more modern gcc versions actually
handled the exception more gracefully.  Our original workaround was to
compile postgresql with libstdc++ linked in at the top of the DLL list
(even ahead of libc) so that exceptions would be caught by a runtime
library that knew what to do with them. In the absence of a windows
native compiler that will do nice things for us, we might have to
revert to doing our own windows native compilation with the libstdc++
hack again in order to catch the exceptions.
P
On Wednesday, January 12, 2005, at 06:40 AM, Obe, Regina DND\MMIS wrote:
> I was doing a trial port of my data from Cygwin PostGreSQL 7.4
> Postgis 0.8
> To Native Windows PostGreSQL  8.0.0 RC4, postgis 0.9.
> 2 issues -  these could be caused by something wrong with my
> reconfiguration
> since there are so many variables that have changed so not sure if
> they are
> problems or not.  I just wanted to know if others have run into similar
> issues.
> When I was testing the geom_union function on one of my tables
> On the cygwin install I get the following behavior
> SELECT geomunion(the_geom) from neighborhood;
> results in Geos throwing the below error
> ERROR:  GEOS union() threw an error!
> NOTICE:  TopologyException: side location conflict (780343,2.95405e+06)
> select geomunion(the_geom) from neighborhoods where name
> IN('Dorchester',
> 'Charlestown');
> Results in
> SRID=102686;MULTIPOLYGON(((778278.699002388  .........
> Same Tests on the: Native Windows PostGreSQL  8.0.0 RC4, postgis 0.9.
> (I'm
> using the PostGIS that came packaged with 8.0.0 RC4 official release)
> Result: The postgres connection crashes without throwing an error so I
> need
> to reconnect.
> IN('Dorchester',
> 'Charlestown');
> Result - No SRID shows
> SRID=-1;MULTIPOLYGON(((778278.699002388
> Other functions such as collect for example return an SRID on both
> installs
> and I checked the table and the geometry_columns table and both
> register an
> SRID.
> I tried reloading the table from the original shape file using the
> newer
> shp2pgsql and the same error still stands.
> postgis-users mailing list
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
