[postgis-users] Possible issue with Geos on PostgreSQL 8.0 Native Windows
strk at refractions.net strk at refractions.net
Wed Jan 12 07:52:19 PST 2005
Which GEOS version ?
--strk;
On Wed, Jan 12, 2005 at 09:40:52AM -0500, Obe, Regina     DNDMIS wrote:
> I was doing a trial port of my data from Cygwin PostGreSQL 7.4  Postgis 0.8
> To Native Windows PostGreSQL  8.0.0 RC4, postgis 0.9.
> 2 issues -  these could be caused by something wrong with my reconfiguration
> since there are so many variables that have changed so not sure if they are
> problems or not.  I just wanted to know if others have run into similar
> issues.
> When I was testing the geom_union function on one of my tables
> On the cygwin install I get the following behavior
> SELECT geomunion(the_geom) from neighborhood;
> results in Geos throwing the below error
> ERROR:  GEOS union() threw an error!
> NOTICE:  TopologyException: side location conflict (780343,2.95405e+06)
> select geomunion(the_geom) from neighborhoods where name IN('Dorchester',
> 'Charlestown');
> Results in
> SRID=102686;MULTIPOLYGON(((778278.699002388  .........
> Same Tests on the: Native Windows PostGreSQL  8.0.0 RC4, postgis 0.9. (I'm
> using the PostGIS that came packaged with 8.0.0 RC4 official release)
> Result: The postgres connection crashes without throwing an error so I need
> to reconnect.
> 'Charlestown');
> Result - No SRID shows
> SRID=-1;MULTIPOLYGON(((778278.699002388
> Other functions such as collect for example return an SRID on both installs
> and I checked the table and the geometry_columns table and both register an
> SRID.
> I tried reloading the table from the original shape file using the newer
> shp2pgsql and the same error still stands.
> postgis-users mailing list
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
