[postgis-users] Unable to create Postgis 1RC1 with GEOS-Support
strk at refractions.net strk at refractions.net
Thu Jan 20 08:43:25 PST 2005
On Thu, Jan 20, 2005 at 05:06:24PM +0100, Düster Horst wrote:
> I try to compile PostGIS 1RC1 with GEOS-2.1.1 support. I follow
> README.postgis and set in Makefile.contrib USE_GEOS=1 and
> GEOS_DIR=/usr/local the correct path to lib/libgeos.so
You mean Makefile.config, right ?
> GEOS-2.1.1 is correcty compiled and installed.
> After make and make install of PostGIS 1RC1 and psql -f lwpostgis.sql all
> GEOS based functions like buffer() GeomUnion() etc. are installed, but the
> command: select buffer(geo,10) from geo_table; responses with
> ERROR:  buffer:: operation not implemented - compile PostGIS with GEOS
> support
> and select postgis_geos_version() responses with NULL.
Did you have an older postgis installed ?
If so you need a dump/reload as all your function definitions
must be changed to use the new library file, which is non-compatible
with older geometry internal format.
If you did not have an older postgis installed please
send the output of your 'make' invocation.
--strk;
> My system:
> ReaHat: 7.2
> GCC: gcc version 2.96 20000731 (Red Hat Linux 7.2 2.96-124.7.2)
> Postgresql: 8.0.0
> Postgis 1RC1
> GEOS-2.1.1
> What do I wrong?????
> With best regards
> Dr. Horst Düster
> GIS-Koordinator /Amtschef Stv.
> Kanton Solothurn
> Amt für Geoinformation
> Abteilung SO!GIS Koordination
> Werkhofstr. 65
> CH-4509 Solothurn
> Tel.: ++41 (0)32 627 25 32
> Fax: ++41 (0)32 627 22 14
> horst.duester at bd.so.ch
> www.sogis.so.ch
> postgis-users mailing list
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
