[postgis-users] Re: PG 8.0 and PostGIS 1.0 RC1 onWindows2003overlap
strk at refractions.net strk at refractions.net
Tue Jan 25 01:30:53 PST 2005
Here is a patch for the bug in transform():
Index: lwgeom_transform.c
RCS file: /home/cvs/postgis/postgis/lwgeom/lwgeom_transform.c,v
retrieving revision 1.11
diff -U2 -r1.11 lwgeom_transform.c
--- lwgeom_transform.c  7 Jan 2005 14:23:07 -0000       1.11
+++ lwgeom_transform.c  25 Jan 2005 09:38:50 -0000
@@ -243,4 +243,5 @@
        PG_LWGEOM *geom;
        PG_LWGEOM *result=NULL;
+       LWGEOM *lwgeom;
        PJ *input_pj,*output_pj;
        char *input_proj4, *output_proj4;
@@ -251,5 +252,5 @@
        result_srid   = PG_GETARG_INT32(3);
-       if (result_srid  == -1)
+       if (result_srid == -1)
                elog(ERROR,"tranform: destination SRID = -1");
@@ -307,8 +308,18 @@
        pfree(input_proj4); pfree(output_proj4);
-       /* Compute bbox if input had one (COMPUTE_BBOX TAINTING) */
        srl = SERIALIZED_FORM(geom);
-       result = PG_LWGEOM_construct(srl, result_srid,
-               TYPE_HASBBOX(geom->type));
+       /* Re-compute bbox if input had one (COMPUTE_BBOX TAINTING) */
+       if ( TYPE_HASBBOX(geom->type) )
+               lwgeom = lwgeom_deserialize(srl);
+               lwgeom_dropBBOX(lwgeom);
+               lwgeom->bbox = lwgeom_compute_bbox(lwgeom);
+               result = pglwgeom_serialize(lwgeom);
+       else
+               result = PG_LWGEOM_construct(srl, result_srid, 0);
        PG_RETURN_POINTER(result); // new geometry
--strk;
On Tue, Jan 25, 2005 at 10:24:51AM +0100, strk at refractions.net wrote:
> Mmm.. I wouldn't use GeometryFromText with a BOX3D argument.
> I think it should only accept 'text' as it has been done with GeomFromWKB
> only accepting bytea.
> Beside this, you can use asEWKT(geometry) to see Extended WKT.
> .. And .. I've found the bug.
> The transform() functoin is failing to transform/recompute an already
> cached bbox.
> I'm working on it.
> --strk;
> On Tue, Jan 25, 2005 at 09:07:39AM -0000, Mark Cave-Ayland wrote:
> > Hi Randy,
> > I get exactly the same results as you on Linux and Windows. Here is my
> > reproducable test script from your email:
> > CREATE TABLE "public"."ibus"
> >             "id" integer NOT NULL DEFAULT
> > nextval('public.ibus_id_seq'::text),
> >             "type" varchar(3),
> >             "unitid" varchar(40),
> >             "groupcode" varchar(40),
> >             "personid" varchar(40),
> >             "triptype" varchar(10),
> >             "latitude" float8,
> >             "longitude" float8,
> >             "time" timestamp,
> >             "gpsdatavalid" varchar(2),
> >             "the_geom" geometry,
> >             CONSTRAINT "ibus_pkey" PRIMARY KEY ("id"),
> >             CONSTRAINT "$1" CHECK ((srid(the_geom) = 4269)),
> >             CONSTRAINT "$2" CHECK (((geometrytype(the_geom) = 'POINT'::text)
> > OR (the_geom IS NULL)))
> > CREATE INDEX ibus_idx ON ibus USING gist (the_geom);
> > INSERT INTO "public"."ibus" ("id", "type", "unitid", "groupcode",
> > "personid", "triptype", "latitude", "longitude", "time", "gpsdatavalid",
> > "the_geom") VALUES(105, 'SOR', 'SCO6aa29-f25f-4744-83dc-4a5ecc3ea192',
> > '2004-12-15T15:37:55.506Z', '00000000-0000-0000-0000-000000000000', 'R',
> > 33.633904, -111.84864, '2004-12-15 15:37:55.506', '1',
> > 'SRID=4269;POINT(-111.84864 33.633904)');
> > "the_geom") VALUES(781, 'SOR', 'SCO6aa29-f25f-4744-83dc-4a5ecc3ea192',
> > '2004-12-18T04:38:38.541Z', '00000000-0000-0000-0000-000000000000', 'R',
> > 33.580818, -111.881256, '2004-12-18 04:38:38.541', '1',
> > 'SRID=4269;POINT(-111.881256 33.580818)');
> > postgis100rc1=# select id, type as name, AsText(the_geom) from ibus where
> > type='SOR' and the_geom && transform(GeometryFromText('BOX3D(284519.3
> > 3769952.1,496251.69999999995 3596407.1)'::box3d,26712),4269);
> >  id | name | astext
> > (0 rows)
> > postgis100rc1=# select astext(transform(GeometryFromText('BOX3D(284519.3
> > 3769952.1,496251.69999999995 3596407.1)'::box3d,26712),4269));
> > astext
> >  POLYGON((-113.293895748635 32.4858065872829,-113.335183599007
> > 34.0499185167345,-111.041304089383 34.0721027704559,-111.040564853023
> > 32.5067173345671,-113.293895748635 32.4858065872829))
> > (1 row)
> > type='SOR' and the_geom && GeometryFromText('POLYGON((-113.293895748635
> > 32.4858065872829,-113.335183599007 34.0499185167345,-111.041304089383
> > 34.0721027704559,-111.040564853023 32.5067173345671,-113.293895748635
> > 32.4858065872829))', 4269);
> >  id  | name |            astext
> >  105 | SOR  | POINT(-111.84864 33.633904)
> >  781 | SOR  | POINT(-111.881256 33.580818)
> > (2 rows)
> > Very strange - this seems like a bug from here. Strk, I was looking at
> > whether the SRID was getting lost in the BOX3D conversion, but AsText()
> > doesn't output the SRID (since it's not part of the OGC spec) it's quite
> > hard to do. Is there a way to get the full 'SRID=x;POINT(x y)' output for a
> > geometry?
> > Kind regards,
> > Mark.
> > WebBased Ltd
> > South West Technology Centre
> > Tamar Science Park
> > Plymouth
> > PL6 8BT
> > T: +44 (0)1752 791021
> > F: +44 (0)1752 791023
> > W: http://www.webbased.co.uk <http://www.webbased.co.uk/>
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Randy
> > George
> > Sent: 24 January 2005 18:05
> > To: 'PostGIS Users Discussion'
> > Subject: RE: [postgis-users] Re: PG 8.0 and PostGIS 1.0 RC1
> > Hi Jean David,
> >             Thanks for checking. I am still baffled.
> > As a further check I installed the PG8.0/PostGIS 1.0rc1 on another Windows
> > XP system and attempted the same query but again the result is empty?
> > I then went back to Windows 2003 and reinstalled from scratch a new download
> > of PG8.0 and PostGIS 1.0rc1 again empty results?
> >             I have run the test query from PGAdminIII, DBTool Manager, and
> > Eclipse DB Browser all with same empty results?
> > There must be some simple explanation of where I've gone wrong?
> > Thanks
> > Randy
> >   _____
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of TECHER
> > Jean David
> > Sent: Friday, January 21, 2005 10:16 AM
> > To: PostGIS Users Discussion
> > Subject: Re: [postgis-users] Re: PG 8.0 and PostGIS 1.0 RC1 on
> > Windows2003overlap
> > Hi George
> > Your general query (from linux with your own data from yoru e-mail)
> > select id, type as name, AsText(the_geom) from ibus where type='SOR' and
> > works for me on windows xp with the same expected results
> > TECHER Jean David
> > Responsable Informatique 01MAP
> > e-mail: davidtecher at yahoo.fr
> > Bureau: 04 67 45 60 27
> > Portable: 06 85 37 36 75
> > site perso : http://techer.pascal.free.fr/postgis/
> > site pro: http://www.01map.com/download/
> > K-S:"The greatest trick the devil pulled off was convincing people he didn't
> > exist"
> > ----- Original Message -----
> > From: Randy  <mailto:rkgeorge at cadmaps.com> George
> > To: 'PostGIS Users  <mailto:postgis-users at postgis.refractions.net>
> > Discussion'
> > Sent: Friday, January 21, 2005 5:58 PM
> > Subject: RE: [postgis-users] Re: PG 8.0 and PostGIS 1.0 RC1 on Windows
> > 2003overlap
> > Hi,
> >             I successfully installed a version of PostGIS on a test windows
> > system thanks to Mark's installer. However I am running into a problem with
> > a simple spatial query. The original query works fine on an earlier Linux
> > setup. For some reason the identical spatial query using a box3d transform
> > from srid=26712 ( utm83-12m ) to srid=4269 (LL)  works on the previous setup
> > but not the new windows setup?
> > Perhaps someone could help point out my error below:
> > Previous query using Linux PG 7.4 PostGIS 0.8.0 (I've included a test table
> > at the end.)
> > results OK:
> > 105;"SOR";"POINT(-111.84864 33.633904)"
> > 781;"SOR";"POINT(-111.881256 33.580818)"
> > New test using PG 8.0 and PostGIS 1.0 RC1 on Windows 2003
> > results empty?
> > Test1: PG 8.0 and PostGIS 1.0 RC1 on Windows 2003
> > This verifies correct transform?
> > select AsText(transform(GeometryFromText('BOX3D(284519.3
> > "POLYGON((-113.293160109785 32.4857520041516,-113.334429907594
> > 34.0498920281307,-111.040622350418 34.0720603897317,-111.039903423973
> > 32.5066459734368,-113.293160109785 32.4857520041516))"
> > Test2: PG 8.0 and PostGIS 1.0 RC1 on Windows 2003
> > This verifies overlap with SRID=4269
> > the_geom && GeometryFromText('BOX3D(-113.3344299323
> > 34.0498929284,-111.0399034240 32.5066459726)'::box3d,4269)
> > results OK:
> > However combining overlap with the box3d transform gives an empty result
> > set?
> > Test table:
> >             "type" varchar(3),
> >             "latitude" float8,
> >             "longitude" float8,
> >             "time" timestamp,
> > Thanks
> > Randy
> >   _____
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
