[postgis-users] Intersects with empty boxes error
Daniel FAIVRE daniel.faivre at camptocamp.com
Tue Jan 25 09:43:08 PST 2005
Ok, thank you, but:
1) It worked on previous versions.
2) geometryfromtext('BOX3D(10 10, 10 10)', -1) does NOT fail to create a
geometry, even if the box collapses to a point. Should it allow creating
"geos unvalid geometries" ?
DF
strk at refractions.net wrote:
>On Tue, Jan 25, 2005 at 05:13:22PM +0100, Daniel FAIVRE wrote:
>>Hello,
>>With a code developped for previous versions, I've used to test
>>intersections, within, or contains with "point  boxes": like this:
>>1) SELECT intersects(geometryfromtext('BOX3D(10 10, 10 10)', -1),
>>geometryfromtext('BOX3D(0 0, 20 20)', -1))
>>A true result is expected, like for:
>>2) SELECT intersects(geometryfromtext('BOX3D(10 10, 10 10)', -1),
>>My new version is:
>>POSTGIS=0.9.1 GEOS=2.1.1 PROJ=Rel. 4.4.7, 31 March 2003 USE_STATS
>>DBPROC=0.0.1 RELPROC=0.0.1
>>The old one was a postgis 0.8.1 with GEOS 1.0
>>It has worked before, but now, request 1 return a false result. Is it a
>>known bug ?
>Your BOX3D is not a valid GEOS geometry (collapses to a POINT).
>You can't expect operations on non-valid geoms to return valid results.
>--strk;
>>Sincerely yours,
>>Daniel FAIVRE
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
