[postgis-users] UPDATE_GEOMETRY_STATS() usage ??
Gregory S. Williamson gsw at globexplorer.com
Tue Jan 25 14:34:49 PST 2005
Try single quoting the parameters being passed into the procedure, e.g.:
select * from update_geometry_stats('xxdrain','the_geom');
HTH,
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From:	David.Jacques at CCRS.NRCan.gc.ca [mailto:David.Jacques at CCRS.NRCan.gc.ca]
Sent:	Tue 1/25/2005 7:18 AM
To:	postgis-users at postgis.refractions.net
Cc:
Subject:	[postgis-users] UPDATE_GEOMETRY_STATS() usage ??
As per section 3.4 of the FAQ for speeding up queries &
Display of large spatial tables I have created indexes on them using
CREATE INDEX [indexname] ON [tablename] USING GIS ( [geometrycolumn]);
However running this: SELECT UPDATE_GEOMETRY_STATS(xxdrain,the_geom); gives
 an error telling me that column "xxdrain" doesn't exist.
I've looked in the  function list and this function is overloaded,
1 form with 2 varchar params and one with only 1 (column name expected).
However running what this other form expects also gives an error.
Any examples of a successful run of this to ensure my spatial indexes and
Statistics are up to date would be great.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
