[postgis-users] Small oversights in PostGIS 1.0 RC1 and migration help
Gino Lucrezi gino-postgis at lucrezi.net
Thu Jan 27 04:57:59 PST 2005
> > Obviously, in an existing DB, I can't just drop the table and recreate
> > it according to the newest spatial_ref_sys.sql file, because there
> > are constraints forbidding it; is there any simple way to do it?
> Postgis itself does not set constraints to them, you could check if
> the new entries from spatial_ref_sys.sql are correct and use
the new ones.
Oppsss... my mistake.
The actual constraints are something like:
CONSTRAINT "$1" CHECK ((srid(the_geom) = 26592))
which does not create a foreign key relationship with the spatial_ref_sys table.
> > Also, utils/postgis_restore.pl doesn't work well if
> > internationalization variables LANG, LANGUAGE or LC_ALL
> > aren't set correctly; it won't reimport tables which have
> > international characters.
> > I'll have to test if reimporting using psql works OK
Anyone has any experiences on that?
I know it's a postgreSQL issue, but maybe...
Gino Lucrezi
Penta Consulting Services
