[postgis-users] Query Performance Problem
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Jan 28 01:23:21 PST 2005
Hi Dirk,
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Dirk Jesko
> Sent: 27 January 2005 16:30
> To: PostGIS Users Discussion
> Subject: [postgis-users] Query Performance Problem
> I am experimenting with PostGIS (currently 1.0RC2) and the
> UMN Mapserver
> on a Windows System. Today I encountered the following problem:
> I have a table "admingebiete" with about 85000 tuples. Each
> tuple has a
> primary key ("gid"), geometry ("the_geom" with
> multipolygons), a feature
> type ("feat_type") and a few other attributes. "gid", "the_geom" and
> "feat_type" are indexed. Since I need only a certain area, which is
> defined by some features in "admingebiete", I create a view that
> calculates the boundary of that area, e.g.:
> CREATE VIEW infogis_area AS
>  SELECT geomunion(admingebiete.the_geom) AS the_geom
>    FROM admingebiete
>   WHERE admingebiete.gid in (410, 422, 423, 424, 426, 427, 430);
> This one takes about 1.3s.
I'm not sure that creating a view for use in a query is the most efficient
way to do this, i.e. returning a single row, as the result of the
geomunion() can be cached assuming your data is static. If you're using a
SRID of -1, you can do something similar to this to cache the union of your
area into a new table called areas:
	CREATE TABLE areas AS (
		name text
	SELECT AddGeometryColumn('', 'areas', 'union', -1, 'POINT', 2);
	INSERT INTO areas (name, union) VALUES SELECT 'infogis_area' AS
name,
	geomunion(admingebiete.the_geom) AS union FROM admingebiete WHERE
	admingebiete.gid IN (410, 422, 423, 424, 426, 427, 430);
> Next, I create a view that selects
> all areas
> from "admingebiete" contained within that area:
> CREATE OR REPLACE VIEW infogis_admin AS
>  SELECT a.oid, a.polygon_nm, a.feat_type, a.the_geom
>    FROM admingebiete a, infogis_area b
>   WHERE a.the_geom && b.the_geom AND contains(b.the_geom, a.the_geom);
With the above in place, this could be replaced by:
		SELECT a.oid, a.polygon_nm, a.feat_type, a.the_geom FROM
admingebiete a, 			(SELECT union FROM areas WHERE name
= 'infogis_area' LIMIT 1) AS b WHERE
a.the_geom);
By using a join, the costly recalculation of geomunion() is avoided in your
main view that you are passing onto Mapserver.
> Mapserver uses this query as the data source for multiple layers. A
> filter based on the "feat_type" attribute is added, e.g.
> "feat_type"='GEMEINDE' (this one takes ~10s for 303 rows).
> Now the problem: Mapserver adds another term to the
> where-clause which
> specifies the area to display,e.g.:
> SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
> from infogis_admin
> WHERE (feat_type='GEMEINDE') and (the_geom && setSRID(
> 'BOX3D(10.0976912562163 51.6005810254548,13.4185945311196
> 52.6039103320119)'::BOX3D,4326) )
> As the result the query runs for ever ( >600s for 303 rows).
> However if
> I put the BOX3D into a table ("test" with just one tuple/no
> index) and
> change the query to:
> SELECT
> asbinary(force_collection(force_2d(a.the_geom)),'NDR'),a.OID::text
> from infogis_admin a, test t
> WHERE (feat_type='GEMEINDE') and (t.the_geom && a.the_geom)
> it delivers the 303 rows in ~10s again.
> So, the questions are: Why does the query take for ever if
> the bounding
> box is specified as text rather than joining it via a table? Is there
> any way to get around this, other than creating separate tables
> containing just the areas needed? Latter approach works fine, but is
> difficult to handle.
> I am currently doing some EXPLAIN ANALYZE for the queries to
> see whether
> there are substantial differences.
As strk suggested, there may be an issue with the join selectivity for && -
I have a feeling that it may be the use of a view that is confusing it.
Please post your EXPLAIN ANALYZE outputs back to the list and we should have
a better idea of exactly what is happening.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
