[postgis-users] My experience in installing RC2
strk at refractions.net strk at refractions.net
Fri Jan 28 08:17:07 PST 2005
On Fri, Jan 28, 2005 at 04:43:53PM +0100, strk at refractions.net wrote:
> On Fri, Jan 28, 2005 at 03:50:49PM +0100, Gino Lucrezi wrote:
(cuts)
> > I decide to try this command line:
> > /configure --with-geos=/usr/local/ --with-proj=/usr/local/
(cuts)
> The --help should have reported that --with-geos arg is full
> path to geos-config. Probably your approach was more intuitive though..
I've patched the script to use the more intuitive approach.
--strk;
