[postgis-users] polygonize and other geometry constructors
Pericles S. Nacionales nacional at cbs.umn.edu
Fri Jan 28 08:25:09 PST 2005
Hey, thanks, Strk!  If had read the README, I would have known about the
lwpostgis.sql.
-Perry
On Friday 28 January 2005 10:14 am, strk at refractions.net wrote:
> On Fri, Jan 28, 2005 at 10:00:02AM -0600, Pericles S. Nacionales wrote:
> > Hi, I'm trying to make polygons out of point geometries and have a couple
> > of questions:
> > 1. Does polygonize work on point geometries or just on lines?
> Should work with every geometry with dimension > 0 (all but points).
> > 2. How does the MakeLine and LineFromMultiPoint work?  I tried both on my
> > point geoms and both returns:
> > ERROR:  function linefrommultipoint(geometry) does not exist
> > HINT:  No function matches the given name and argument types. You may
> > need to add explicit type casts.
> Did you feed the lwpostgis.sql script to your database ?
> Or are you using some custom upgrade method ?
> The calls are correct.
> --strk;
> > I have PostGIS 1.0rc2 compiled with GEOS 2.1.1.   I can use the Collect
> > function to create mulipoint geoms from point geoms but the other
> > functions don't work for me.  What am I doing wrong?
> > Here's are the statements I used for #2:
> > SELECT makeline(the_geom) FROM data WHERE squirrelid=702
> > SELECT linefrommultipoint(collect(the_geom)) FROM data WHERE
> > squirrelid=702
> > While I'm at it, I might as well ask if there are any wildlife/population
> > ecology types out there who use PostGIS?  And if so, have you used
> > PostGIS to do homerange analysis stuff?
> > Thanks,
> > Perry Nacionales
> > Dept. of Ecology, Evolution, and Behavior
> > University of Minnesota
> > work: 612 624 6713
> > e-mail: nacional at cbs.umn.edu
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
work: 612 624 6713
