[postgis-users] Capturing point in time information for groupsof geometries.
Craig Miller craig.miller at spatialminds.com
Mon Jan 31 17:31:49 PST 2005
Kate Hornsby and Max Egenhofer wrote a nice paper on the different states
that an object can be in throughout time.  It contains a model that is
richer than the simple "admission date" and "retirement date".  By
describing the complete set of states that an object can be in, it is
possible to create a formal query spatio-temporal language.  Kate has the
article available as a PDF at
http://www.spatial.maine.edu/~khornsby/publications.html
K. Hornsby and M. Egenhofer (2000) Identity-based change: a foundation for
spatio-temporal knowledge representation, International Journal of
Geographical Information Science.14(3): 207-224.pdf file Figs 10-15 pdf
--Craig
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Monday, January 31, 2005 3:19 PM
To: Eric Merritt; PostGIS Users Discussion
Subject: Re: [postgis-users] Capturing point in time information for
Brute force solutions to temporal problems are commonplace. There are
not a lot of generic elegant solutions, unfortunately, the solution that
suites you best will depend on your problem domain.
Many operational spatial database systems want to maintain "time travel"
capability -- the ability to find the state of the data at any past
time.  One common way of doing this is to give every field an extra pair
of attribute datestamps, an "admission date" and a "retirement date".
Then, finding a version of the database becomes a fairly simple exercise
in SQL.
However, such a database can be a pain to work with for day-to-day
operational tasks (because it is full of legacy information as well as
current information).
A simple way of trading disk space for complexity is to keep two copies
of your database around.  A copy that is a "current operation" version,
and a "versioned" copy.  By putting update/insert/delete triggers on all
your "current operation" tables, you can cause the "versioned" copy to
be kept in sync with the changes that occur on the operational data.
This is a nice way to maintain versioning without imposing the overhead
of a versioning system on your end users.  Of course, it has *other*
overheads, in terms of space and performance.
Everything is trade-offs.
Yours,
Paul
Eric Merritt wrote:
> I need to capture point in time information for groups of geometries
> (maps basically). The goal is to see how things change over time. I
> havn't come up with any simple and reliable way to do this as yet. I
> have a couple of simple and strait forward ways to do it but they are
> more brute force, non-optimal approaches. Do any of you have similar
> requirements? Would you mind sharing your solutions?
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
