[postgis-users] Conversion WGS84 to Lambert II
Nicolas Ribot nicky666 at gmail.com
Tue Jul 5 09:32:16 PDT 2005
> Hello,
> I have GPS coordinates and I would like to INSERT this
> coordinates to Postgis Database, but I don't know how
> can I transform the coordinates wgs84 to Lambert II
> 27582.
> These are the coordinates in WGS84
> LATITUDE        LONGITUDE
> N4902.4761      E00201.7400
> I would like to have coordinates in order to create an
> sql Insert
> INSERT INTO "popplace" ("id","the_geom") VALUES
> ('1',GeometryFromText('POINT (xxxx yyyy)',27582));
> Best regards,
> LEVERT Donovan.
Hi donovan,
you can use the transform() function to reproject your data on-the-fly
when inserting them.
Something like:
INSERT INTO "popplace" ("id","the_geom") VALUES (
'1',
transform(GeometryFromText('POINT (2.017400 49.024761)', 4326), 27582)
Check the corresponding SRID for WGS84 (on my postgis version, its 4326).
(I assumed that your given lat long coordinates should be read in
decimal degrees)
Nicolas
