[geos-devel] Re: [postgis-users] Error compiling PostGIS + GEOS
Chip Masters chip_masters at yahoo.com
Thu Jul 7 09:32:10 PDT 2005
I don't know if it was run at install, but rerunning
it now did the trick. Now lwpostgis.sql loads fine.
Thanks for everyone's help! I'm sure I will be posting
back here regularly as I dig in.
Chip
--- strk at refractions.net wrote:
> Did you run 'ldconfig' after GEOS install ?
> --strk;
> On Wed, Jul 06, 2005 at 12:31:21PM -0700, Chip
> Masters wrote:
> > GEOS and PostGIS users,
> > Since I last posted on this thread about my
> > installation problems, we upgraded our OS to SuSE
> 9.2
> > with the 2.6.8-24.16-default kernel. Also, for the
> > record, we are using gcc version 3.3.4.
> > Now after installing PostgreSQL 8.0.3, PostGIS
> 1.0.1
> > with the flags set in Makefile.config to include
> PROJ
> > and GEOS:
> > > USE_PROJ ?= 1
> > > PROJ_DIR ?= /usr/local
> > > USE_GEOS ?= 1
> > > GEOS_DIR ?= /usr/local
> > I try to do
> > > psql -f lwpostgis.sql -d test
> > from within the postgis-1.0.1 install directory,
> and I
> > get this error:
> > > psql:lwpostgis.sql:36: ERROR:  could not load
> > library > "/scratch/pgsql/lib/liblwgeom.so.1.0":
> > libgeos.so.2: > cannot open shared object file: No
> > such file or
> > > directory
> > I notice that the liblwgeom.so.1.0 library doesn't
> > link to the geos or proj libraries:
> > > postgres at cyc11:~/lib> ldd liblwgeom.so.1.0
> > >         linux-gate.so.1 =>  (0xffffe000)
> > >         libstdc++.so.5 =>
> /usr/lib/libstdc++.so.5
> > > (0x40067000)
> > >         libgeos.so.2 => not found
> > >         libproj.so.0 => not found
> > >         libgcc_s.so.1 => /lib/libgcc_s.so.1
> > > (0x40125000)
> > >         libc.so.6 => /lib/tls/libc.so.6
> (0x4012d000)
> > >         libm.so.6 => /lib/tls/libm.so.6
> (0x40243000)
> > >         /lib/ld-linux.so.2 => /lib/ld-linux.so.2
> > > (0x80000000)
> > even though both libgeos.so.2 and libproj.so.0 are
> > present in /usr/local/lib.
> > Can anyone help here? Should the PROJ_DIR and
> GEOS_DIR
> > variables in the Makefile.config point to
> > /usr/local/lib instead of /usr/local?
> > Thanks,
> > Chip Masters
> > > On Tue, Jun 21, 2005 at 03:45:51PM -0700, Chip
> > > Masters wrote:
> > > > We did compile GEOS (PostgreSQL and PostGIS as
> > > well)
> > > > with GCC 3.4.3.
> > > Are you sure you don't have old c++ headers
> around ?
> > > Can you seek that __builtin_new symbol in system
> > > headers ?
> > > --strk;
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
> ____________________________________________________
> > Sell on Yahoo! Auctions – no fees. Bid on great
> items.
> > http://auctions.yahoo.com/
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
Sell on Yahoo! Auctions – no fees. Bid on great items.
