[postgis-users] PostGIS schemas
Jan Hartmann j.l.h.hartmann at uva.nl
Tue Jul 12 03:37:00 PDT 2005
Hi Gaby,
I can only answer your second question:
 > b. How I can create multiple PostGIS connections, each from a
 > different schema/?/
You can set the search_path to whatever schema(s) you want in the
connection string:
CONNECTION "dbname=mydb options='-c search_path=myschema,public'"
The "public" schema has to be in the search_path, else PostGIS won't
find its geometry_columns and spatial_ref_sys tables.
Jan
Gaby wrote:
> Hi there
> I am investigating the use of PostGIS with both uDig and Quantum GIS. I
> should add that I come out of an Oracle Spatial background. I am a
> complete novice at PostGIS. I have converted 5 different data sets with
> a total of 65 SHP files. For practical reasons I want to keep the tables
> from each dataset in different schemas.
> Please note the following background:
> - I am doing all of the work on a standalone machine that I use as both
> client and server.
> - I am running Windows XP SP2
> Now the problem; in both of the products I am trying (uDig and Quantum
> GIS), I can view all of the tables from all of the schemas when logged
> on as schema owner of any one schema. However, as expected, I can only
> view the data from the schema I logged on as.  This leads me to the
> following questions:
> a. Why is it that after logging on as a particular user/schema owner, I
> can list ALL of the tables, regardless of the schema they belong to? (I
> suspect that since both products work the same that it is a PostGIS /
> PostGreSQL anomaly, not problems with uDig or Quantum GIS?)
> b. How I can create multiple PostGIS connections, each from a different
> schema/?/
> Yours Sincerely
> Gaby van Wyk
> postgis-users mailing list
