Res: Re: [postgis-users] How to drop a PostGIS table ?
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Tue Jul 12 11:39:29 PDT 2005
Thank you Nicolas.
-------Mensagem original-------
De: Nicolas Ribot
Data: 07/12/05 14:40:56
Para: PostGIS Users Discussion
Assunto: Re: [postgis-users] How to drop a PostGIS table ?
> Hello,
> I would like how to drop a PostGIS table on Postgresql.
> Does anyone knows how to drop it and all the relations on the tables
spatial_ref_sys" and "geometry_columns"
Hi Ezequias,
There is a function that does the trick (as stated in the documentation) :
"DropGeometryTable([<schema_name>], <table_name>)
Drops a table and all its references in geometry_columns. Note:
uses current_schema() on schema-aware pgsql installations if schema is
not provided."
Nicolas
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050712/08de003d/attachment.html>
