[postgis-users] Trouble getting PostGIS data to display in MapServer
Paul Ramsey pramsey at refractions.net
Thu Jul 14 11:27:59 PDT 2005
Try setting your SYMBOL to "circle" or really anything other than the
default (which I think is dimensionless and therefor immune to SIZE).
When you set your postgresql statement logging on, do you see
mapserver making queries? If so, what do they look like?
Does the apache hit in your apache logs include the cities layer
name? (Ie, are you sure your client is asking for it?)
P
On 14-Jul-05, at 11:00 AM, Jason Burkhardt wrote:
> Thanks for the quick response.
> I've tried with just about every combination of lat/long (including
> -72)
> with no results.  I was just using the list here:
> http://www.realestate3d.com/gps/uslatlongdegmin.htm so I'm really
> not sure
> if they're all hosed or what.  My current viewer's extents extend from
> central america up to the north pole so I figured I would have hit
> something in the area by now ;)
> I modified my .map file as per your suggestions to look like this:
>         CONNECTION "user=postgres password=pgadmin dbname=test
> host=localhost port=5432"
>         DATA "point from cities using unique oid using SRID=4326"
> I assume that's what you meant for the DATA clause.  I know for
> sure that
> MapServer is connecting to the database & executing the queries, I
> can see
> as much in the PostgreSQL logs.
> If I set the layers status to default it's turned off when I load
> up my
> viewer & I'm still unable to display it when I turn it on and
> refresh the
> viewer.
> Jason
> |         |           Nicolas Ribot <nicky666 at gmail.com>|
> |         |           Sent by:                          |
> |         |           postgis-users-bounces at postgis.refr|
> |         |           actions.net                       |
> |         |           07/14/2005 01:45 PM               |
> |         |           Please respond to Nicolas Ribot;  |
> |         |           Please respond to PostGIS Users   |
> |         |           Discussion                        |
>   |       To:       PostGIS Users Discussion <postgis-
> users at postgis.refractions.net>
> cc:
>   |       Subject:  Re: [postgis-users] Trouble getting PostGIS
> data to display in
> MapServer                                                      |
> Hi Jason,
> Just some thoughts:
> try to explicitly add PG port in your connection string (5432 is the
> default)
> try to set the layer's status to DEFAULT in order to force its
> display.
> in your DATA clause, maybe try adding "using unique oid using
> SRID=4326".
> Are you sure your points' extent fall in your mapserver map extent ?
> Shouldn't Albany's longitude be -72 instead of 72 (West from greenwich
> Nicolas
> On 7/14/05, Jason Burkhardt <jburkhardt at usgs.gov> wrote:
>> I'm really sure this must be something simple I'm missing, but I'm
>> at my
>> wits end and am not getting any further by staring at it.
>> Hopefully a
>> fresh set of eyes can help me out.
>> I'm running MapServer & have a viewer up displaying data from a
>> variety
> of
>> sources (WMS, .tif's, shapefiles) and would like to include
>> PostGIS data.
>> I created a simple PostgreSQL db with a table called cities (this
>> table
> was
>> created with oids) that has a name, state_name and point field.
>> I created the point field as such:
>>       select AddGeometryColumn('cities', 'point', 4326, 'POINT', 2);
>> A sample of the data I'm inserting looks like this:
>>       insert into cities (name, state, point) values('Albany', 'NY',
>> GeometryFromText('POINT(73 42)',4326));
>> I then created 2 indexes as so:
>>       CREATE INDEX cities_index ON cities USING GIST (point
>> GIST_GEOMETRY_OPS)
>>       CREATE INDEX cities_index_oid ON cities (name)
>> I've also done the second index with point as the unique column, I
>> don't
>> really care which it is at this point.
>> Onto MapServer my layer definition looks like this:
>> LAYER
>>   CONNECTIONTYPE postgis
>> host=localhost"
>>   DATA "point from cities"
>>   NAME "PostGIS Cities Test"
>>   TYPE POINT
>>   STATUS ON
>>   CLASS
>>       COLOR 255 0 0
>>       SIZE 50
>>   END
>>   PROJECTION
>>     "init=epsg:4326"
>>   END
>> END
>> Every other layer I have is also 4326.  It's connecting to the
>> database &
>> not throwing any errors that I can see from the PostgreSQL logs
>> (I've run
>> them with varying levels of verbosity).  MapServer does not return a
> broken
>> image when the layer is turned on, I just don't see the point
>> displayed.
>> I would appreciate any comments/insight.
>> Thanks,
>> Jason
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
