[postgis-users] Interested in PostGIS for a replacement to ArcSDE
Randy George rkgeorge at cadmaps.com
Mon Jul 18 07:15:20 PDT 2005
	In some scenarios, especially those involving web interfaces, you
might consider dropping ESRI and switching to some other interface based on
open standards. There are some alternatives like svg+xml, MapServer, JUMP
which have active communities. PostGIS can do all the heavy lifting
geospatial work and the middle tier can be a customized interface based on
w3c and OGC standards.
	You can save on license aggravation and have a much more interactive
interface with the additional assurance that the standard is not going to be
moved out from under you with the next release.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Guy
Carpenter
Sent: Monday, July 18, 2005 1:43 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Interested in PostGIS for a replacement to
ArcSDE
Awww, rats.  Compare that to this press release:
http://www.esri.com/news/arcnews/fall04articles/arcgis9-plans.html
"The ArcGIS Schematics and ArcGIS Data Interoperability extensions,
 which are already available for the 9.0 release, will become fully
 integrated in the core ArcGIS software at the 9.1 release."
I guess this is a new use of the phrase "fully integrated" that I've
been previously unaware of.
In October last year I also explored the pgoledb
development project at
	http://gborg.postgresql.org/project/oledb
hoping to use it as glue between ArcGIS and PostGIS.
I was unable to make ArcGIS play nicely with pgoledb.
I determined that ArcGIS was talking to the driver,
but I was never able to open a data source.
Guy Carpenter
Atherton Tablelands GIS
http://atgis.com.au
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Asger
Petersen
Sent: Friday, 15 July 2005 10:14 PM
To: postgis-users at postgis.refractions.net
ArcSDE
> With the 9.1 release, ESRI have bundled the Data Interoperability
> Package into the core product - no extra licensing fee.
> Also Safe Software (authors of the Interop. extension) were busily
> working on fixes to the bugs in the extension last year.
> I haven't tried using PostGIS from ArcGIS 9.1, but it sounds like all
of
> the
> pieces may be in place to make it work.
Hi
When activating the Data Interoperability extension in ArcGIS 9.1 it
says:
"The ArcGIS Data Interoperability extension, a new extension introduced
after the release of 9.0, is now part of the ArcGIS Desktop setup and so no
longer has to be installed separately. A license still has to be purchased
to use this extension."
It is possible to try it out for free for 60 days. I haven't tried it yet,
but a friend of mine has tried and his ArcGIS crashes every time he tries to
establish a PostGIS connection.
Well, it sounded really good, but...
/Asger Petersen
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
