[postgis-users] How to configure JUST the loader on a client machine
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jul 19 07:05:29 PDT 2005
strk at refractions.net wrote:
> On Mon, Jul 18, 2005 at 03:22:50PM -0400, Stephen Woodbridge wrote:
>>Hi all,
>>Is there any way to be able to configure and build just the loader
>>utilities without all of PostGIS and postgres install or configured. I
>>have some systems that do remote data crunching and load the results
>>into postgis on another system. I need to be able to configure and build
>>shp2pgsql and pgsql2shp utilities on a system that does not have all the
>>rest of the stuff loaded.
>>How can I do this?
> You should, did you try ?
Yes, I tried. ./configure -- autoconfig which wants to know where the
postgres source dir is and fails without it. And if that does not run,
then Makefile.global does not exist doe the Makefile in the loader dir
does not run.
The box I'm running on is Debian Sarge.
-Steve
> --strk;
> postgis-users mailing list
