[postgis-users] Help, What am I missing gist_geometry_ops column???
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jul 19 08:44:46 PDT 2005
Mark and Jan,
Thanks, that was the problem. Seems to be working now.
-Steve
Mark Cave-Ayland wrote:
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>Behalf Of Stephen Woodbridge
>>Sent: 19 July 2005 16:31
>>To: PostGIS Users Discussion
>>Subject: [postgis-users] Help, What am I missing
>>Hi all,
>>I'm try to create a postGIS table in a schema and it is
>>mostly working,
>>but I am having trouble building an index.
>>1. loaded the postGIS extensions and spatial references into schema
>>"public" like normal
>>2. created tables and loaded the data in my own schema like:
>>### Drop the table if it exists
>>echo "DROP TABLE swoodbridge.rgeo;" | psql -U pgsql -h localhost dev
>>### Define the table so we can load data into it
>>FILE=`ls e*/*.shp | head -1`
>>shp2pgsql -p -s 4326 -g the_geom $FILE swoodbridge.rgeo |
>>psql -U pgsql
>>-h localhost dev
>>### Append each of the files to the table
>>for FILE in e*/*.shp ; do
>>     shp2pgsql -a -s 4326 -g the_geom $FILE swoodbridge.rgeo
>>| psql -U
>>done
>>The above all works and looks ok.
>>3. tried to create an index:
>>dev=# create index rgeo_gidx on swoodbridge.rgeo using gist
>>(the_geom,
>>gist_geometry_ops);
>>ERROR:  column "gist_geometry_ops" does not exist
>>I seem to have missed a critical step, but not sure what.
>>Any help would be appreciated.
>>-Steve
> Hi Steve,
> I don't think there should be a comma after the column name - try just
> simply:
> create index rgeo_gidx on swoodbridge.rgeo using gist (the_geom
> gist_geometry_ops);
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-users mailing list
