[postgis-users] pgsql2shp segfault by multipolygon export
strk at refractions.net strk at refractions.net
Thu Jul 21 13:57:02 PDT 2005
I suggest you download and build postgis-1.0.2
You should be able to use the pgsql2shp distributed with it
against older databases. If the problem persists please let us know.
--strk;
On Thu, Jul 21, 2005 at 07:56:50PM +0800, ch.grau at uni.de wrote:
> hi all,
> i have a problem while exporting an multipolygon layer with pgsql2shp.
> exports of lines and points are ok
> i'm using suse 9.2 / postgresql 8.0.2 and postgis-0.9.1 on 64bit
> i get following error messeage
> test:~ # /usr/local/pgsql/bin/pgsql2shp - f /var/pg_backup/shapes/test -P mutsave -u postgres test_db test_table
> Initializing... Done.
> Dumping: XSegmentation fault
> thanks for help
> christian grau
> FreeMail und FreeSMS auf www.uni.de
> postgis-users mailing list
