[postgis-users] pgsql2shp segfault by multipolygon export
ch.grau at uni.de ch.grau at uni.de
Fri Jul 22 04:14:20 PDT 2005
hi all :-)
i have build postgis-1.0.2 but multipolygon export still does not work.
the error message
./pgsql2shp -f test.shp -P test -u test_user test_db test_table
Initializing...
Done (postgis major version: 0).
Output shape: Polygon
Dumping: XSegmentation fault
kernel message:
pgsql2shp[14742]: segfault at 0000000000000000 rip 0000000000408817
rsp 0000007fbfffe670 error 6
thanks for help
christian grau
>I suggest you download and build postgis-1.0.2
>You should be able to use the pgsql2shp distributed with it
>against older databases. If the problem persists please let us know.
>--strk;
>On Thu, Jul 21, 2005 at 07:56:50PM +0800, ch.grau at uni.de wrote:
> hi all,
> i have a problem while exporting an multipolygon layer with pgsql2shp.
> exports of lines and points are ok
> i'm using suse 9.2 / postgresql 8.0.2 and postgis-0.9.1 on 64bit
> i get following error messeage
> test:~ # /usr/local/pgsql/bin/pgsql2shp - f /var/pg_backup/shapes/test -P mutsave -u postgres test_db test_table
> Initializing... Done.
> thanks for help
> christian grau
> FreeMail und FreeSMS auf www.uni.de
> postgis-users mailing list
