[postgis-users] Gentoo Emerge (from Gerald FENOY)
Jean David TECHER davidtecher at yahoo.fr
Wed Jul 27 01:44:32 PDT 2005
could you give me which is the version of the ebuild youve used to
make this test ?
Could you give me the emerge logs of this emerge ? (Indeed I would
like to see if you don't have some trace of an old installation on
your system, cause in that case portage will not remove the old
one...)
Cordially.
PS: Sandro could U add gfenoy at gmail.com as a sender for this mailling list, indeed he experiences a tecnical problem on his djayux.net mail server :/
  ----- Original Message -----
  To: postgis-users at postgis.refractions.net
  Sent: Tuesday, July 26, 2005 11:54 PM
  Subject: [postgis-users] Gentoo Emerge
  I Installed Postgis on Gentoo using:
  USE="geos proj doc" ACCEPT_KEYWORDS="~x86" emerge postgis
  select postgis_version() = 1.1 USE_GEOS=0 USE_PROJ=1 USE_STATS=1
  Does this mean it's still not using GEOS? If so what should I do to make
  it use GEOS?
  postgis-users mailing list
  http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050727/deeb1177/attachment.html>
