[postgis-users] Buffer Question
Jeff Grice jgrice at predictioncompany.com
Wed Jul 27 05:27:49 PDT 2005
I am using PostgreSQL 8.0.3 on WindowsXP Professional and PostGIS
version 0.9.
I want to return a list of cities within a certain distance of a point.
Note my city table is in srid=4269 which has units in degrees, so I must
transform it to srid=2163 to get to units in meters.
Select *
from city
where buffer(transform(GeomFromText('POINT(-98.20194
32.22056)',4269),2163), 100000) &&
transform(city.the_geom, 2163)
However when I run the buffer function I get
ERROR: Operation on two GEOMETRIES with different SRIDs
I started dissecting the query and found the following:
Using SELECT transform(GeomFromText('POINT(-98.20194
32.22056)',4269),2163) I return:
	"SRID=2163;POINT(170540.337643801 -1435432.98097678)"
All is well; my srid = 2163 just as I would expect.
However, if I buffer the point with:
SELECT buffer(transform(GeomFromText('POINT(-98.20194
32.22056)',4269),2163), 10000)
My result returns srid = -1
How do I return a buffer result in srid=2163?
If I read the documentation correctly, the result should be in the same
spatial ref sys as the geometry passed in (in this case 2163).
Any help would be greatly appreciated.
Jeff
