Res: Re: Res: Re: [postgis-users] dropping geometry tables
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Fri Jul 29 07:02:51 PDT 2005
I checked the  geometry_columns and ezequias tables with the command \d
There is no problem now.
Thank you Nicolas
-------Mensagem original-------
De: Nicolas Ribot
Data: 07/29/05 10:33:48
Para: PostGIS Users Discussion
Assunto: Re: Res: Re: [postgis-users] dropping geometry tables
> Thank you, but:
> dbpotgis-# DropGeometryTable('ezequias');
> ERROR:  syntax error at or near "DropGeometryTable" at character 1
> dbpotgis=#
try
select DropGeometryTable('ezequias');
Also, check your table's schema (type: \d ezequias at the psql command
prompt).
If schema is not "public", you should pass it as the function's argument.
Nico
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050729/34a772fb/attachment.html>
