[postgis-users] polygon holes
strk at refractions.net strk at refractions.net
Mon Jun 6 10:18:13 PDT 2005
On Mon, Jun 06, 2005 at 10:59:41AM -0600, Sean M. Montague wrote:
> 1.0.1. I am exporting from ArcView 3.3 with a script I wrote.  My
> constructed export statement looks like this:
> INSERT INTO "test_02" ("objectid","name","layer","the_geom")
> VALUES ('1','1','1',GeometryFromText('MULTIPOLYGON(((-290334 1359643,
> -290334 1600755, 5121 1600755, 5121 1359643, -290334 1359643))((-221218
> 1433507, -94067 1433507, -94067 1531640, -221218 1531640, -221218
> 1433507)))',32767))
> The response I get is: " ERROR:  parse error - invalid geometry"
It is invalid, you need a comma between components POLYGONS.
Old postgis acceptance of this syntax was a surplus (bug actually).
--strk;
> Thanks.
> Sean
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Monday, June 06, 2005 10:51 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] polygon holes
> On Mon, Jun 06, 2005 at 10:30:16AM -0600, Sean M. Montague wrote:
> > I just upgraded to PostGIS 1.0, and I'm having a problem exporting
> > polygons with holes, lakes with islands for instance.  I was not
> having
> > problem before with version 0.9. Am I missing something?  Thanks.
> > Sean
> By "exporting" you mean pgsql2shp usage ?
> Can you tell us exact version of PostGIS (postgis_full_version)
> and RCSID of pgsql2shp (call w/out args) ?
> --strk;
> postgis-users mailing list
