[postgis-users] Intersection errors
Sean M. Montague smontague at ATSDenver.com
Tue Jun 7 11:01:19 PDT 2005
I take it back.  It does work.  When I export to SVG, I set
fill-rule="evenodd", and the hole appears.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sean
M. Montague
Sent: Tuesday, June 07, 2005 11:46 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Intersection errors
I just tested it, it does not work.  Very interesting.  This explains a
lot.  Is there not a way to cut holes in polygons?
M. Montague
Sent: Tuesday, June 07, 2005 11:41 AM
It's a hole.  It should be valid...I think.  What about islands in a
lake?  The only time I have a problem with them is when I intersect one.
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Tuesday, June 07, 2005 11:35 AM
Subject: Re: [postgis-users] Intersection errors
It's not valid, because legal multipolygons do not have parts that
interact. Your multipolygon has two parts and one is completely
contained in the other. No cookie for you!
Paul
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
