[postgis-users] INSERT geom Problem
Mike Leahy
mgleahy at fes.uwaterloo.ca
Sun Jun 12 10:04:52 PDT 2005
Levert,
I think you can cast the text as geometry as follows:
INSERT INTO "popplace"
("unique_key","name","the_geom") VALUES
('124','London','SRID=27582;0101000000000000A053984241000000C0789A3141'::geometry);
Mike
Levert Donovan wrote:
>Hello,
>This is the continuation of the message Postgis
>Problem , I continued on the problem and I discover
>where is the problem.
>It is a problem from INSERT and the AddGeometryColumn.
>this INSERT works fine :
>('128','pari',GeometryFromText('POINT(0 0
>0)',27582));
>But this INSERT doesn't work :
>('124','London','SRID=27582;0101000000000000A053984241000000C0789A3141');
>Do you what is the format of
>'SRID=27582;0101000000000000A053984241000000C0789A3141',
>how can I convert this to GeometryFromText() function
>Best Regards.
>Donovan LEVERT
>___________________________________________________________________________
>Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
>Téléchargez cette version sur http://fr.messenger.yahoo.com
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
