AW: [postgis-users] Update-Problem under Windows
Uwe Seher uwe.seher at arteng.de
Tue Jun 14 00:37:13 PDT 2005
Thank you!
This may bee the error. I've run postgis.sql all the time.
Uwe Seher
> -----Ursprüngliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Im Auftrag von
> Steffen Macke
> Gesendet: Dienstag, 14. Juni 2005 09:20
> An: PostGIS Users Discussion
> Betreff: Re: [postgis-users] Update-Problem under Windows
> Uwe,
> the installer will just install the PostGIS version in parallel to
> the old one (because of the switch from postgis.dll to lwpostgis.dll).
> After running the installer you have to upgrade your database(s).
> If you have only tested PostGIS so far, the easiest way to
> upgrade might be to
> simply drop the database, create a fresh one, load PostGIS to it
>  (by running lwpostgis.sql) and load your data again.
> If you are running PostGIS in a production environment already, you
> may want to use
> the upgrading procedure described in the PostGIS documentation using
> postgis_restore.pl
> However, this will require PERL.
> Regards,
> Steffen
> postgis-users mailing list
____________
Virus checked by G DATA AntiVirusKit
