[postgis-users] seq scan for spatial operator
Paul Ramsey pramsey at refractions.net
Tue Jun 21 10:17:32 PDT 2005
That is by design, that is how indexes work in PostgreSQL. Only SQL that
uses an operator (in your case, &&) will access the index. Your first
query does not have an operator, it has only a function(). Spatial SQL
should always look (generally) like this:
SELECT <various things>
FROM <various table>
WHERE
   <an indexed && test>
AND
   <an exact function() test>
Xavier Vanderstukken wrote:
> The following query performs seq scan on all the table (600.000row for
> 1matched result).
> select * from foo where equals (asText(foo.geom),'POLYGON ((4.3596
> 50.51121,4.3597584 50.51127,4.35994 50.511333,4.3601313
> 50.511406,4.360355 50.511482,4.35968 50.511448,4.3596 50.51121))')
> -->30sec response time
> but if I add and intersect request :
> foo.geom&& GeometryFromText('.............',-1)
> -->response time 50ms no seq scan
> _________________________________________________________________
> Protégez votre boîte de réception: Phishing : comment l'identifier, le
> signaler et l'empêcher   http://www.fr.msn.be/security/phishing/
> postgis-users mailing list
