[postgis-users] Spheroid Question
Markus Schaber schabi at logix-tt.com
Tue Jun 28 06:23:27 PDT 2005
Hi, Stephen,
Stephen Woodbridge wrote:
>>> the_geom && expand(setSRID(makepoint(-72.607912,
>>> 42.058052),4326),0.179664)  AND
>> [Meters per degree]
> You are correct that degrees per meter increases, but we are concerned
> with meters per degree in this example and being the inverse they
> decrease. So by using the value at the equator, we over sample as we
> move toward the poles which is ok, unless it creates a performance
> problem in which case you will have to expand the bbox x and y as you
> suggest.
AFAICS, you give an degree value 0.179664 to expand in your example, and
this makes the bbox too narrow when going to the poles.
Markus
