[postgis-users] collect(geom) in rc3?
Mike Leahy mgleahy at fes.uwaterloo.ca
Thu Mar 3 14:58:26 PST 2005
Hey all,
I think maybe my message (below) was overlooked because I forgot to
change the subject.  Does anyone else have the same problem I've got
with using the collect() function?  Is it just a Win32 problem, or maybe
even just my own isolated problem?  Maybe someone else with RC3 can give
the collect() function a try...
Thanks,
Mike
Mike Leahy wrote:
>Hey folks,
>I'm going to suggest that RC3 is not ready...I just tried out the Mark's
>installer and ran into trouble.  There are still issues with MapServer
>connectivity, which are effectively the opposite of the problem that I had with
>RC2.  To get a mapserver to draw a layer from a postgis points table using RC2,
>I had to use the following DATA string:
>DATA "the_geom from (select oid, place_id, entry, name, collect(the_geom) as
>the_geom from gis_culturepoints group by oid, place_id, entry, name) as foo
>using srid=32619 using uniqe oid"
>It's not ideal, but I guess that the 'collect(the_geom)' solved a problem with
>force_collection() not working, am I right?  At any rate, after installing RC3
>(with PostgreSQL 8.0.1/WinXP, etc), the same DATA string causes postgres to crash.
>I changed the DATA string for the layer back to what it normally would be, and
>had no problems with mapserver:
>DATA "the_geom from gis_culturepoints using srid=32619 using uniqe oid"
>Just to be sure, I tried the collect() function in psql from a command window,
>and it crashed as well, so I think this is a more significant bug than just
>MapServer connectivity:
>testdb=# select collect(the_geom) from gis_culturepoints;
>server closed the connection unexpectedly
>        This probably means the server terminated abnormally
>        before or while processing the request.
>The connection to the server was lost. Attempting reset: Failed.
>So...my first guess is that perhaps whatever fix solved the force_collection()
>problem also broke the collect() function, though maybe something else
>altogether has happened.
>FYI: When I uninstalled RC2, I verified that that the postgis-related dlls and
>sql files (that I know of) were successfully removed.  I backed-up all
>non-spatial tables, and dropped my database.  After installing RC3, I recreated
>my database, reloaded the spatial table from scripts previously generated by
>shp2pgsql, then reloaded the other non-spatial tables.  Is there anything I
>might have missed that could be causing an incompatibility with my current
>PosgreSQL installation and RC3?
>Does anyone know of anything else I should mention, or any tests I should perform?
>Kind regards,
>Mike
>Quoting Mark Cave-Ayland <m.cave-ayland at webbased.co.uk>:
>>>-----Original Message-----
>>>From: postgis-users-bounces at postgis.refractions.net
>>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>>Behalf Of Markus Schaber
>>>Sent: 03 March 2005 11:14
>>>To: PostGIS Users Discussion
>>>Subject: Re: [postgis-users] Ready for 1.0.0 ?
>>(cut)
>>>Do you think an RC4 would be the correct solution to make the
>>>people test the latest fixes? Strk could then release 1.0.0
>>>unchanged if RC4 is fine.
>>Yes, I think especially as strk has fixed one crashing bug since then. I'm
>>just not convinced that RC3 has been out long enough for people to test to
>>make sure that the Mapserver connector issues have been solved etc.
>>>Fine. What is your experience building the jdbc2 stuff on
>>>windows? I'm pretty shure some additional weird problems
>>>might pop up there. You should check out the latest CVS, as
>>>there are some Makefile changes compared to RC3 that may ease
>>>building in your environment.
>>The only change I've had to make so far is to change RUNCP and BUILDCP to
>>use semi-colons instead of colons - otherwise the building under Windows
>>fails. I don't know if it's possible to build some of this functionality
>>into the Makefile or to just simply make a note of it in the comments
>>somewhere.
>>Another thing: I've compiled the JARs as standard using a 1.4 JDK. However
>>the notes on jdbc.postgresql.org aren't particularly clear as to which
>>versions to use. In particular, it notes that JDBC1 is obsolete with
>>PostgreSQL 8.0. What do you think would be the best way to compile the jdbc2
>>driver? I'm thinking of compiling with a -target 1.3 option, and including
>>the resulting standard/debug JARs in the Win32 installer?
>>>I think we should make as much testing as possible.
>>Agreed. I must admit I haven't looked at the regression tests in a long time
>>to see what coverage they give us, but I'm hoping that passing the
>>regression tests should be a good enough indication that PostGIS works on a
>>particular platform.
>>Kind regards,
>>Mark.
>>WebBased Ltd
>>South West Technology Centre
>>Tamar Science Park
>>Plymouth
>>PL6 8BT
>>T: +44 (0)1752 791021
>>F: +44 (0)1752 791023
>>W: http://www.webbased.co.uk
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>This mail sent through www.mywaterloo.ca
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050303/5fdfd241/attachment.html>
