[postgis-users] geometry column
w m wokar1 at yahoo.com
Wed Mar 9 20:16:52 PST 2005
Hi
Im tryin to populate my geometry column in my postgresql database usin pgadmin
i get the following errors (i have also included a screen snapshot)
SQL error:
ERROR:  column "latitude" does not exist
In statement:
INSERT INTO "geometry_columns" ("f_table_catalog", "f_table_schema", "f_table_name", "f_geometry_column", "coord_dimension", "srid", "type", "attrelid", "varattnum", "stats") VALUES (Latitude, public, 'Hotspots', circle, '45.5177', '1', polygon, '1', '1', '1')
i have a column called latitude in my table hotspots.
is it necessary to enter values in each field??
in the coord_dimension field does i have to be x,y format or can it be any value or does it have to be the latitudes
im doing all this because i would like to use this command pgsql2shp...but first i need to fill the geometry column because otherwise i get the following error
-bash-2.05b$ pgsql2shp Montreal Hotspots
Initializing... No geometry column found.
The DBF file will be created but not the shx or shp files.
Done.
Dumping: XX [4 rows]
Thank You
Nisa
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050309/39665609/attachment.html>
Name: geometry table.bmp
Type: image/bmp
Desc: geometry table.bmp
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050309/39665609/attachment.bin>
