[postgis-users] Unusual Make/Compilation Error - postgis-1.0.0-rc3
Tomeh, Husam htomeh at firstam.com
Wed Mar 16 09:25:44 PST 2005
Hello,
According to the sysadmin, the make I used is a GNU make.
Thanks,
anadev10#pkginfo -l SMCmake
   PKGINST:  SMCmake
  CATEGORY:  application
      ARCH:  sparc
   VERSION:  3.80
   BASEDIR:  /usr/local
    VENDOR:  Free Software Foundation
    PSTAMP:  Steve Christensen
  INSTDATE:  Mar 15 2005 13:51
     EMAIL:  steve at smc.vnet.net
    STATUS:  completely installed
     FILES:       50 installed pathnames
                   5 shared pathnames
                   7 directories
                   1 executables
                4661 blocks used (approx)
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
strk at refractions.net
Sent: Friday, March 11, 2005 10:24 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Unusual Make/Compilation Error -
postgis-1.0.0-rc3
On Fri, Mar 11, 2005 at 04:11:17PM -0800, Tomeh, Husam wrote:
> I have installed PostgreSQL 8 on my Solaris 2.8 dev machine. I
> installed
> Proj.4 and GEOS spatial libraries and have been trying to install the
> PostGIS library with no luck so far. I downloaded and extracted
> postgis-1.0.0-rc3 under the the contrib subdirectory. When I run
> "make", I get errors not finding other Making.* files under "src". I
> checked for these Making.* files and they do exist!! However; I keep
> getting the following errors when I run "make":
You need GNU make, try 'gmake' instead of 'make' and see if it fixes the
problem.
--strk;
> anadev10 /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3 :) make make
> -C lwgeom
> make[1]: Entering directory
> `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> ../Makefile.config:90: /src/Makefile.global: No such file or directory
> Makefile:98: /src/Makefile.shlib: No such file or directory
> make[1]: *** No rule to make target `/src/Makefile.shlib'.  Stop.
> make[1]: Leaving directory
> make: *** [liblwgeom] Error 2
> Any idea is highly appreciated. Thanks,
>    Husam
> This message contains confidential information intended only for the
> use of the addressee(s) named above and may contain information that
> is legally privileged.  If you are not the addressee, or the person
> responsible for delivering it to the addressee, you are hereby
> notified that reading, disseminating, distributing or copying this
> message is strictly prohibited.  If you have received this message by
> mistake, please immediately notify us by replying to the message and
> delete the original message immediately thereafter.
> Thank you.                                       FADLD Tag
> postgis-users mailing list
