[postgis-users] Postgres 8.1beta2 crash with 3D (and beyond) geometries..
strk at refractions.net strk at refractions.net
Tue Nov 1 10:46:24 PST 2005
Can you provide a backtrace of the call ?
--strk;
On Sun, Oct 30, 2005 at 08:16:16PM +0100, Alex Mayrhofer wrote:
> Hi,
> I'm trying to use geometries with dimensions > 2 on one of my test
> machines. Table creation was fine (i was using a 4D POINT geometry),
>   however, when PostGIS tries to parse a POINT geometry with dimension > 2
> (tried with 3d/4d, just POINTs), Postgres crashes:
> first is fine, second makes postgis crash:
> geotest=# select geomfromtext('POINT( 0 0)');
>                 geomfromtext
>  000000000100000000000000000000000000000000
> (1 row)
> geotest=# select geomfromtext('POINT( 0 0 0)');
> WARNING:  OGC WKT expected, EWKT provided - use GeomFromEWKT() for this
> CONTEXT:  SQL function "geomfromtext" statement 1
> server closed the connection unexpectedly
>         This probably means the server terminated abnormally
>         before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
> !> \q
> This can be reproduced at any time.
> I'm running the following configuration:
> geotest=# select postgis_full_Version();
>                                          postgis_full_version
>  POSTGIS="1.0.4" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.0" RELPROC="0.3.0"
> (1 row)
> geotest=# select version();
>                                               version
>  PostgreSQL 8.1beta2 on sparc-unknown-linux-gnu, compiled by GCC cc (GCC)
> 3.3.5 (Debian 1:3.3.5-13)
> (1 row)
> Everything seems to run fine for 2D geometries - this was my first attempt
> at 3d geometries on this box.
> The system is an UltraSparc machine, Postgres as well as PostGIS are
> running in 32bit userland. A gdb backtrace of a crashed postmaster shows a
> SIGBUS, and a corrupted stack.
> Can i track this down somehow in a "standalone mode" of PostGIS only? I'd
> rather not like to recompile Postgres to include debugging stuff..
> I'd appreciate any comments on how to proceed here - still hoping i've
> triggered a well-known bug...
> thanks
> Alex Mayrhofer
> postgis-users mailing list
